Hi guys
forgive me if i post in the wrong section.
i just read the other topic regarding this CRC but to Hardware itself.
What about CRC error when copying/moving big chunk of video files
from my local drive to other partition drive?
How can i fix this ?
please advise
That means that your computer couldn't read from either your source or your destination drive. This could be just a temporary thing that a reboot may fix, or if it happens frequently then your hard drive might be on the way out. If running XP (Hint: update your computer details in your profile!), Check the drive(s) for errors by right-clicking on the drive in My Computer, going to Properties, Tools, and click the "Check Now" button where it says "Error-checking".
Or you could try a good old-fashioned CHKDSK froma command prompt - google will give you a range of switches you can use with it.If in doubt, Google it.
Crc error
By Hell Bound in forum DVD RippingReplies: 6Last Post: 6th Nov 2010, 06:00 -
CRC Error on Data File, CHKDSK Fails to Repair, Now What?
By PartingShot in forum ComputerReplies: 6Last Post: 16th Dec 2009, 16:56 -
Software Help: CRC Error "File Broken", But Video Still Plays and
By mike69 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2009, 10:15 -
Help Cannot Unzip Last File CRC Error
By mn072065 in forum ComputerReplies: 16Last Post: 18th Jul 2007, 09:48 -
damaged file(crc error) how to get it off dvd
By invadar in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 08:59
