IS it possible to convert multiple (say 22) avi files to DVD at once and so that it is one DVD file?
Results 1 to 14 of 14
Join the .avi files in virtualdub. Than encode to DVD. Its unnecessary though, you can author those without joining. Encode indivdually, then author together..
Quality is my policy. -
It's called Authoring.Originally Posted by Seagrass
If you want a one-click wonder, you could use DivxToDVD and select all 22 files, and this will encode and author all 22 AVIs to seperate titlesets. No menus though, and little to no control over any settings.
Get the free version from here and knock yourself out - remember though, to click on the last file in your list, then hold shift down and click on the first file, and this will convert them in the right order.
or do it the manual way, and set up your encoder to encode all 22 files overnight or something. Then author.If in doubt, Google it. -
Ok thanks jim
How do you set tmpenc to do 22 files automatically overnight?
I thought I'd have to do each one manually -
If not in the wizard, set up each one, then go to File > Add current project to batch list > MPEG file. Select a destination and filename for the file and then you should be shown a "running sheet", showing your queued up file. Set up next encode, and do the same as above, and then you'll see two jobs in the Batch section. Repeat until you have all files set up.
If using the wizard, there's a tickbox on the last screen that says either "encode straight away" or "add more projects to batch" or words to that effect.
Tip: If you want all files to be processed with exactly the same settings, set up the first one, then save the settings as a custom template. then just load each new file in turn, and load the saved template, and all settings will be identical.If in doubt, Google it. -
IS there any way to retain AC3 using tmpenc?
The only audio options i see in tmpenc is mpeg2 , lame mp3 or PCM.
Also, do i really have to save each file's audio to wav in virtualdub in preperation for the DVD -
so i need to extract the audio using virtual dub, convert video only in tempenc then join them together when burning to a DVD?
Sorry if Im a bit slow, I only just got a DVD Burner today.
I tried DivXToDVD and it seems really slow. Whats the general opinion of that program in regards to video/audio quality. Will the output be the same as the source quality or more importantly will it leave AC3 in tact and not convert it to MPEG -
If you've got AC3 in your source files, and you want to keep it intact, then don't extract to WAV. You can just demux it using virtualdubmod. Then do your video only in TMPGEnc and join the M2V files up with your demuxed AC3 files in your authoring software.
You think DivxToDVD is slow !!! hmmmmmmm ..... I've found it to be quicker ... much much quicker than TMPGEnc, and a lot of other similar apps. AFAIK it will convert any audio you throw at it to 2ch AC3. Quality-wise it is the best all-in-one one-click-wonder I've seen. For other peoples' opinions of this software, check out the tool's comments section:
https://www.videohelp.com/tools?tool=vso_DivXtoDVD#usercommentsIf in doubt, Google it. -
damn I cant see the option to demux anywhere in virtualdubmod 1.5
How do I demux an AC3 file? -
Streams --> Streams List --> Choose demux, name it, save it.
or you could check this tutorial.
https://www.videohelp.com/forum/viewtopic.php?t=273886
However, I don't think you should put more than 12 episode in one DVD.
Since you have 22 episodes, you could make 2x 11.
It would take... 15 hours of converting for the whole 22 episodes, if you're using CCE. Then you will only have to author.
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Multiple DivX to 1 DVD
By zenn68 in forum Video ConversionReplies: 5Last Post: 9th Aug 2009, 18:47 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 08:57 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
