    Aug 2005
    Australia
    Hi,i want to convert full length movies (700mb)which are avi format to 3gp files so i can play them on my nokia,the best encoder i have used is SUPER © v1.802 but i cant get it to convert files over 300mb,when i try to play the 3gp file after conversion i get a messasge saying "The content format of the opened file is not supported".But if the avi file is under 300mb it converts fine,i have tried to convert other type of files that are over 300mb but also get the message of death.Can anyone please tell me how i can convert avi files that are over 300mb in size to 3gp files using SUPER © v1.802....thanks...
  2. Would it be possible to split the files before running them through super ? IE 200Mb, 250Mb, 250Mb if you're sure it is a size issue.
    as a workaround split the file with VDub or have you run GSpot to see if they have different Codecs?
