Hi all. Question. I have some AVI film files. Is it really worth converting these to MP2 (DVD) just so that I can get them onto a DVD disk? Or, should I just convert them to VCD and put them on a CD? The point I'm trying to make is, will converting an AVI to Mpeg2 really give a quality increase?
Results 1 to 10 of 10
Depends on the quality and frame size of your source. But in short, if your AVI files are significantly better than VCD quality you'll get better results with DVD MPEG2 if you allow enough bit rate.
Ok thanks. One more question, when I finally convert from AVI to Mpeg 2, I find that the files are too big to go on a 4.7gb DVD? Any tips?
use a bitrate calculator and calculate what bitrates you need to use so that they do fit.
... and unless you're a guru with filters, converting AVI to MPEG-2 will never give a quality increase. Just because you convert something to DVD specs doesn't make it "DVD quality" automagically.If in doubt, Google it. -
I never said it would. In fact, that was the initial question!!!
Bitrate calculator? Where can I get one from. -
http://members.dodo.net.au/~jimmalenko/calc.htmIf in doubt, Google it. -
Originally Posted by jimmalenko
/Mats -
I just love that word!
Donadagohvi (Cherokee for "Until we meet again") -
Originally Posted by mats.hogberg
My statement, all other things withstanding, is true and correct. Basically what you're saying is that DVD-compliant MPEG-2 would more than likely be the lesser of the three evils - and I'm certainly in full agreement with thatIf in doubt, Google it.
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 00:12 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
avi to avi without any quality loss?
By pike8 in forum Video ConversionReplies: 4Last Post: 10th May 2009, 10:39 -
[Help] avi to wma keeping avi quality?
By Riddick51PB in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 18:13 -
avi quality better then vhs quality?
By NateDizzle in forum Video ConversionReplies: 7Last Post: 11th Jun 2007, 08:20
