  1. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    G'day
    Does anyone know how to send attachment to the forum? Can it be done? I
    cannot find the function. I'm using FF. Cokies, Java and Java Scripts enabled.
    Anything alse I need.
    John
    Click on post reply and browse for the file under "Upload image or file".
    And you must also type [url]filename.zip[/url] in the post or you wont get a link to the file.
  3. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Just testing
    no luck
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That just creates a link that says http://filename.zip ...
    I've found that the best way is to upload the file "silently" - that is, upload the file but don't put the link to it in your original post, then edit the post, then put the [url]filename.zip[/url] in and it then links properly.
    @jollyjohn:
    I think there's a 2MB limit on files you can upload, and there's also restrictions on what file-types you can upload also. Try zipping or rarring whatever it is you are trying to upload, make sure it's under 2MB, then post a new post with whatever text you need in it, browse to your file and hit submit. Remember to not attempt to link the file in the post yet!
    Once uploaded, edit your post, add in [url]filename.zip[/url] to the body of your post and hit submit again, and it should link properly this time.
    If in doubt, Google it.
  5. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Testing again
    [url]ZDO2O8KVHR\Desktop\Windows XP Crashed.zip[\url]
  6. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    and again
    windowsxpcrashed
  7. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    And again
    windowsxpcrashed
  8. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks Jim
    I could not open the file in a readable format. I added a zip extension and there it was.
    Thanks again.
    John
