I've been trying to convert videos on my computer (mainly avi, some mpg) to SVCDs so that I can watch them on my DVD player, but I can't work out how to do so.
I've tried using AVI2DVD and Boilsoft AVI to VCD/SVCD/DVD Converter, but neither seem to work. I select to convert the AVI file into SVCD format, but then when it's finished all it gives me is an mpeg file. I thought SVCD files were .bin and .cue, that you then burn as a disc image? Where am I going wrong? Am I supposed to burn the mpeg file to a disc? Do I need to do something different to give me .bin and .cue files?
Also, once I've worked out how to convert AVI files to SVCD, is there anyway to burn multiple AVI files onto one SVCD, or is it one video per disc?
Any help is appreciated, but please bare in mind that I'm a total newbie to this, so please try to explain things in as little technical detail and as simple as possible.
Thanks![]()
Results 1 to 16 of 16
In most cases, you won't want too, as the quality will decrease.
Google is your Friend -
But how else can I get it to play on my DVD player? I don't have a DVD writer..Originally Posted by Krispy Kritter
But doesn't that just give me an mpeg file? What do I do with the mpeg file?Originally Posted by BJ_M
You will need to convert the avi to mpg (ensure that the mpg file meets svcd specs), split the file into 2 or 3 pieces and then burn.
All of the above steps are covered in the HOW TO section.Google is your Friend -
An Svcd is a particular configuration of MPG file.
A bin/cue is a disk image, could be of anything. -
WinAVI
https://www.videohelp.com/tools?tool=WinAVI_Video_Converter
hands down the best and fastest. I think I've tried just about everything and this is the only one that works well for me.
DVDSanta
https://www.videohelp.com/tools?tool=dvdSanta
worked OK too. Both of these are trialware (I think).
Don't waste your time with anything else and while youre at it why not just convert to DVD instead of SVCD. OF course the quality will depend on the source but you can fit a lot more on just one disc.
You can then use DVD Decrypter to burn to DVD
https://www.videohelp.com/tools?tool=DVD_Decrypter
hope this helps -
Keeping in mind that SVCD discs hold less than 50 minutes per disc, so it becomes not how many AVIs per disc but how many discs per AVI.
I don't have a DVD writer unfortunately.Originally Posted by gguerra3
I've just converted a movie using TMPGEnc, but yeah the mpeg has come out as about 1.3 GB, so won't fit on a single disc.
But now I have converted to an mpeg with that program, how do I burn it onto a disc using Nero? Do I select the "burn SVCD" option and just drag the mpeg file into it there?
Do VCDs hold more than SVCDs, but lower quality? If I burn it was an VCD instead, will it all fit on one disc? My DVD player says its plays SVCDs, so does that mean it will also play VCDs?
Thanks -
Originally Posted by Grazzer
Sorry, I meant to edit the post, not quote it. -
you could use THEFILMMACINE also - which will make the svcd's and spit them for you also ...
it is not hard to split the mpeg2 files though ... lots of guides here for that
Yes VCD can hold more per disk 80 Minutes on a 700 mb disk but at lower quality. Only way to tell if it works in your machine is try but it should as it is a dvd resolution with lower audio.
Cheers
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:35 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
