Hi,
Just like my title question says, Is there a AC3 plugin for either TMPGenc author 1.5 and OR 1.6 ?
For the past year or so I have been spending too much time spliting the audio from the video and then converting the audio to AC3 in a standalone encoder, and then bringing that AC3 audio back in the Author stage.
Any advice appreciated
cheers Scott
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Take a look at http://www.pegasys-inc.com/en/index.html and you'll find the AC3 plugin.
Artificial intelligence is no match for natural stupidity. -
Yes there is, but it's a pain in the rear, the PC it's on has to have an internet connection. The plug-in calls home on a regular basis, to confirm its registration. You can get it as part of a promo package with TDA from Ecost.com, the price $41. Or, just do without it. If you don't need to edit in TDA and don't care to hear the audio in preview, TDA lets MPEG2 files with AC3 audio pass through (including VOBs).
Yes, there is the plugin, but <rant>IMO, encoding is not a task for the authoring stage. Get your sources in order, then fire up your authoring app.
Next, you want it to encode the video to a suitable format too, and then you are on the verge of the great grey goo of oneclickwonder apps that's been flooding the market lately.
Better an application that has limited scope, but do what it does well, than an app that does it all, but is crap.</rant>
/Mats -
All TMPGEnc software calls home every now and then. It's no big deal, as it only takes a few seconds to verify the program. You're using internet now to post on these forums, aren't you? Well in that time, it would already finish verification. The verification is becoming necessary in all software, because of all the cheap people in the world. This AC3 plugin is the only cheap plugin that is Dolby Certified, but it is only 2.0 channels. You are guaranteed the audio will work in all DVD players. I tried BeSweet and other free AC3 encoders. They gave me problems in my Pioneer player, and in my friends player. MP2 audio is not supported officially for NTSC DVD.
The plugin can also be used standalone. Go into TMPGEnc directory, and run TMPGEnc Sound Player. Then click encode button and drag any WAV files to the encoder, and choose encode.
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
