Hello all
My friend has just purchaced a video camera.
after installing the supplied software on the computer then pluging in the camera in the usb port he gets the following error message.
Device can perform faster if you connect to a high speed USB.2.0 port
For a list click here.
There are no high speed USB host controllers installed on this computer
The computer has six usb ports 4 on the back 2 on the front.
so we do not understand why the error.
The PC is a p-4 1.6 256 ram.
Any advice is much appreaciated
Simply put. the computer has USB 1.0 compliant ports, which will result in slower transfers of pictures. The device may work or maynot. Suggest your friend buy and install a USB 2.0 add on card. This will allow the camera which is USB 2.0 compliant to transfer at the correct speed and thus avoid the error.
Or better yet - a FireWire card, if the cam has FireWire.
/Mats -
. . or purchase a card with both USB2 and firewire. You can usually find them for the same price as USB2 cards. Even if you don't have firewire now, you never know what the future of your computing habits may hold.
Most MiniDV or Digital8 camcorders only provide a highly compressed video stream on the USB port intended for internet streaming. The USB port is also used for still transfer.Originally Posted by jdizzy40
To get a full quality DV transfer, you need to use the IEEE-1394 (aka Firewire, ILink) ports.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 10:57 -
Question about USB to Firewire?
By Lucid_Dream in forum ComputerReplies: 1Last Post: 4th Jan 2011, 12:37 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
question about sony bravia usb connection
By ivyer in forum DVB / IPTVReplies: 3Last Post: 1st Nov 2009, 05:53 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 16:50
