I created my DVD with FC Express and imported it into iMovie HD. Everything went fine. I then went to create DVD with iDVD and after setting up my menus I put a 4.7 GB 120 Min blank DVD in and it told me that the project was to large and to enter a double layered DVD.
Ok the thing is that the total project is only showing 1:12:00 and only 4.3 GB's Total. Now according to that it should fit fine on a DVD.
Can someone please tell me what I am doing wrong or what step I missed. I spent 3 days getting the DVD ready and to then find out it doesn't even fit. aaagggghhhhh...
Thanks in advance for any help....
Jasen
Results 1 to 1 of 1
burning hard subtitles into format to use in idvd?
By matteo121 in forum SubtitleReplies: 3Last Post: 28th Dec 2010, 17:44 -
Burning an iMovie to DVD without having iDVD
By bradelway in forum MacReplies: 3Last Post: 30th Nov 2009, 10:39 -
Converting and burning problems with iDVD 7.0.3
By stormrider76 in forum MacReplies: 5Last Post: 14th Mar 2009, 07:51 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Problem with .dv file that I converted from .vob for iDVD
By eric56 in forum MacReplies: 7Last Post: 9th Jul 2007, 03:25
