question about playlists...
i'm putting together the playlist with all the different movies and it works perfectly BUT...is there a way to make chapters of each movie? I don't think there is but i'm curious if you make a "play all" function if there's a way to have each movie become it's own chapter and go to the next one if you choose to watch it that way.
The way to do that is with movie segments, which effectively joins them together into one title at compile time, with the start of each segment being a chapter stop. You cannot have chapter stops between these points in movie segments though.
Read my blog here.
First, you make each clip play one at a time and return to main menu. Then you use playlist for Play All option.
Please refer to this link to have some idea.
https://www.videohelp.com/forum/viewtopic.php?t=258135&highlight= -
Originally Posted by pchan
Add a chapter mark right before the end of each clip. Then when you hit NEXT, it should jump to the dummy chapter mark, then continue playing to the next clip. As long as you fade to black for each clip, it can be relatively transparent to the viewer...
George -
Go to your movies and right click on the chapter. Select chapter -> add manually... Format ... Frame Number. For PAL, type 25 and NTSC, type in 30. In this way, you should able to skip to the nearest beginning. I usually add chapter about 5 minutes apart for the entire movie clip.
What burning software records a data DVD from playlists?
By Stealth3si in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 23:43 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 21:32 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 20:28 -
dvd lab question
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 22:44 -
DVD Lab question
By rizay in forum ComputerReplies: 7Last Post: 7th Dec 2007, 19:13
