hi im using svcd2dvd software and i have different movie files like cd1,cd2,cd3 you know like parts of a movie. what im trying to do is combine all these parts into one whole movie and burn it on a dvd+r disc. now when i use the merge title button on the svcd2dvd software. when i go to play the movie on my dvd player. the movie plays but it is split in half on the screen . can someone help me
What do you mean by "split in half"?
Upper part/lower part of the screen?
Sounds like a resolution problem, but I don't know this software you use. Is there some setting where you can set the resolution?This is not an optical illusion - it just looks like one. -
side by side . i don't see any setting for the resolution that i can change. do you know of any other software i can you that is simple and easy to work with.
Did you look at the tools Stormin Norman mentioned above?
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 20:33 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 09:13 -
joining/making movie from 2 cds into one with AVI,S
By keithportsmouth in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2008, 12:51 -
Joining DIVX files
By jimbb in forum EditingReplies: 17Last Post: 9th Apr 2008, 11:05 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 14:09
