I'm hoping someone can shed some light on a problem i've been
having recently. I'm trying to convert some AVI files to VCD format,
using the Main Concept encoder version 1.4
The problem is that the resulting vcd file has no audio. Actually the
audio plays for approx 1 second, and stops. The files convert fine using
Tmpgenc or Canopus procoder, but i like using Main concept because its
MUCH faster than either of those. This did work in the past, but suddenly
doesnt work.
The avi file is using the following codecs:
Video :
640 MB, 1384 Kbps, 29.970 fps, 624*352 (16:9), XVID = XVID Mpeg-4
Audio :
59 MB, 128 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3
thanks,
Win
you need to convert the audio into some other format pcm/wav or ac3. DVD usually don't play MP3 audio
Well, the avi has the mp3 audio, and i'm converting this to VCD. Its works with other conversion programs, just not Main Concept.
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
