I've heard some folks author & render in one program then burn the DVD using another program. Any advantages to that? I been using Studio 9 for the complete projects, which are photoshows of my children. I'm starting a new project with 1000+ pictures, with many chapters and added music, and looking at all options for that smooth professional look. Thanks.
Yes. If you author the dvd to your hard drive you can then check it with a software viewer like power dvd or mediaplayer classic to verify that you authored it correctly. Also the burning engines built into some authoring apps are not as good as the burning engines of dedicated burning apps like nero and others. I personally prefer to create an iso with img tools classic and then burn the iso with dvd decrypter.Originally Posted by jmarkosDonadagohvi (Cherokee for "Until we meet again")
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39 -
Author/burn software which burns many mpgs in < time than Win DVD Maker
By wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2011, 12:09 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Author and Burn AVI file with subs
By Squid_uk in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2007, 07:12
