Hi! Here's the problem: I converted and AVI file (with embedded subtitles) to MPEG using TMpgEnc. Then I Recorded this video into a DVD. On my computer I watch it perfectly but when it plays on the TV the video is expanded of such form that the subtitles are outside of the screen. How do I solve that? Is there a specific way to convert that makes it work or the problem is the tv?
Changing the Aspect Ration Options or Video Type helps in any way?
thx!
https://www.videohelp.com/forum/viewtopic.php?p=1040920#1040920
instead of vcd frame sizes use dvd, 720x480/576. -
If you use the wizard,to walk through youre project when you get to this
http://xs.to/xs.php?h=xs42&d=05333&f=Noname.jpg
click other settings,then....
http://xs.to/xs.php?h=xs42&d=05333&f=Nona.jpg
In video arrange method,choose full screen (keep aspect ratio).
Youre subs should be ok now to view. -
I've just tested both options:
This tip worked perfectly!!!Originally Posted by Baldrick
This one didn't.Originally Posted by Soixante
Thx for helping.
Subtitles don't show in preview?
By Inkwolf in forum ffmpegX general discussionReplies: 5Last Post: 27th May 2011, 13:11 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 20:12 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 14:12 -
MaestroSBT, GfD subtitles don't sync with video
By lienny in forum SubtitleReplies: 23Last Post: 15th Feb 2009, 13:57 -
subtitles donīt appear in preview
By nicgrosso in forum ffmpegX general discussionReplies: 7Last Post: 24th Apr 2008, 16:49
