This is "old" news for the satellite fans, but far from mainstream, so here it goes
We now have alternatives to use our Videoguard (NDS) legal subscription cards, on something else than Digibox. There are 4 alternatives:
1 - A Dragon Cam module with the latest predator firmware. With this CAM you can watch Sky Digital (UK/Ire) and Sky Italia on any DVB receiver with a C.I. module. Even a PVR one...
1a - A "Matrix Revolution" or "Matrix Reborn" Cam. Only for Sky Italia (rumours also say Sky Digital, but it didn't worked for me)
2 - Any DVB PCI / USB card compatible with progdvb and the ncemucam102 plug in. You also need a Phoenix Smartmouse at 3Mhz connected to a com port of your PC so to read the card. Tested by me and worked perfect.
Also it is possible to make it work with a Nokia 9600/9500/9200 dvb receiver, using the well known progdvb plug in for this task.
There is only one problem with this alternative: The subscription card doesn't update the keys, so remember to use your digibox one in a while to get the new keys!
3 - Dreambox 56xx and 7X00 DVB receivers, with unofficial firmware images (linux based).
4 - Triple Dragon DVB receiver with unofficial firmware images (linux based). Most things about this receiver are in German only (unfortunatelly)... Best solution from what I know (The card can update so no reason to use digibox and there are even sky plus skins to make triple dragon look like a digibox....)
Remember: All those alternatives can be used ONLY with official legal subscription cards!
I would love to know if Sky Mexico and other American NDS/Videoguard subscription services can work with those alternatives we, the Europeans, now have. Please, if you know, report!
Results 1 to 30 of 46
La Linea by Osvaldo Cavandoli
Hello SatStorm,
I live in Israel, where the satellite company also uses NDS videoguard encryption for their broadcast. The company name is YES and it uses Amos1/2.
I want to use my PC as a PVR using the Dragon CAM with the new firmware (that support videoguard) and the company original smart card.
One member of a hometheater forum in Israel has told me that he has tried it with no success. He believes it is because the module's firmware doesn't include the company's CRYPTO ID.
I don't have much knowledge on this issue, so I’ll be glad if you can answer a few questions:
1. Do you think the guy is right in his assumption?
2. Is it possible to add the ID manually and how?
Thanks -
Dragon CAM doesn't support YES at present (from what I know at least....)
Can anyone tell if any of these options works with the Scandinavina Viasat channels? A year or two ago Viasat switched from Viaccess encryption to NDS VideoGuard encryption.
I read on a Danish forum that Dragon Cam loaded with Predator firmware works with Viasat, but this requires the ident. number of the original receiver that came with the Viasat subscription to be programmed in the receiver-card menu. -
You can use Viasat original NDS card, with an upgraded nokia 9800 DVB/S receiver. Also, only for viasat, an original PCMCI CAM Module is avalaible. This module can 't be used with other NDS cards
Originally Posted by SatStorm
The only ones they will allow to buy CAM's for Viasat are cable TV providers.
Where can you buy an original Viasat NDS card? In Denmark where they operate, everyone says it's impossible to buy an NDS VideoGuard CAM for Viasat. It's only possible to buy approved receivers with built in NDS VideoGuard. It was possible to buy CAM's or the old Viaccess encryption, but I don't beleive it's possible with the new NDS VideoGuard encryption.
If I could buy an original CAM for Viasat VideoGuard, I would just do that, but I don't think it's possible anywhere. Please tell a place to buy them if it is possible.
I would like to get a Viasat CAM so it can be used with a PCI DVB-S card for a HTPC. -
I can't link you where to buy original and legal Videoguard cams. It's a grey area.
Here is a photo of the NDS Cam for Viasat
It is tested with Viasat and works 100% (doesn't work with Sky Digital / Sky Italia)
Technically, you can get the Viasat NDS card only, if you first have a subscription to the other Nordic subscription service, Canal Digital Nordic (Thor satellites, 1 west).
From what I know, most users, BUY the official reciever with the card (so not to be forced to connect the receiver with the telephone line) and then they simply use their CAM insteed (official / dragon, even matrix reload/revolutions/reborn - if you find the proper firmware to upgrade) .
In short terms, if you don't have already a subscription to Canal Digital, you won't be able to buy ONLY the viasat card, you have to buy the receiver too.
Many "advance" users, use their Viasat card with a dreambox DVB receiver or a Triple Dragon one.
The alternative, with a phoenix smart mouse and a PC DVB card compatible with progdvb (example: SkyStar 2), is by far cheaper and easiestLa Linea by Osvaldo Cavandoli
Hi StaStorm,
I am new to this Satdecoders. Can you pls tell me that the solution you have discribe, work in australia f**t** NDS. The 7025 comes with the cable tuner so is it possible to get digital channels via Dreambox7025. thx for your help
Originally Posted by SatStorm -
Well, I live in Europe, so I don't really know what happens to Australia regarding this subject. From what I know, dreambox is capable to emulate what is needed for NDS cards worldwide. Special firmwares also make Dragon (t-rex, diablo, etc) CAMs to handle NDS, but only for European subscription services.
The most universal solution, from what I know, is through SkyStar2, progDVB, NDS cam emulator plug in and a phoenix serial smartmouse at 3.37mhz. This combo never failed from what I know. -
Just for your info, another alternative to the SkyStar 2 card is the Twinhan 1025, I used to own a SkyStar2 and they get terribly hot, you need a PCI fan to keep it cooled.
No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. .. -
I have tried ncemucam102 and i can only get a picture for a few seconds then it goes off, my phoenix is running at 3.57 mhz. do i need to change the resonator/crystal to 3.37 or was that a typing mistake?
i built my own phoenix, and it works now, the one i bought dosent work!
That having been said, from what I understand -- and being a noob I may be wrong -- but for those of us in the States and Canada, apart from Bell ExpressVu I believe the others (StarChoice, DirecTV and DishNetwork) are all using Ku (Kurtz Upper) or Ka (Kurtz After) band Microwave satellite transmissions and the only RF/Microwave Capture Cards I've seen are from a company in Israel, which makes a PCI card with the model number 2030. I believe any other DVB-S receiver card or box is generally an adaptation of this. However, the maximum frequency for this card and other similar ones seems to be about 2.1GHz, where as Ku is around 10GHz and Ka can be around 20GHz (although it ranges from like 13GHz to 40GHz). So, unless I am wrong -- and I probably am -- none of these techniques will work for at least 3 of the North American players. However, only DirecTV uses VideoGuard in the North American Satellite business so this would only pertain to DirecTV anyway.
My personal interest is to build a full-digital MythTV based on the DirecTV / NDS H20 receiver. This receiver is able to decode both MPEG2 and H.264 / MPEG4 codecs, which none of these techniques can seem to handle. In time, I think H.264 will replace MPEG2 so we will see similar boxes someday which support H.264, but not today. It is certainly possible to control this receiver from a MythTV box, but how you get the decrypted video from the STB to the MythTV box without loss is anyone's guess. Even 169time doesn't have a Firewire patch for the H20. -
Hi, i'm new on this forum, my native language is not english, so sorry about my bad english.
About the frequencyes isue, i understand that 10-40Ghz is the Ku frequency but the receiver/pci card receive the FI frequency that is down-converted from the LNB, in other words, the LNB receive 11-12Ghz aprox and deliver 0.9-2.1 Ghz to receiver or digital receiver card.
I have some experience in Latin DTV and Latin Sky systems, and we have never had a emulator, we all think ist is impossible because the asic incoporated in the cards. i reaaly wants to know if there is any way to test here, because since a couple of years ago, we do not have any way to test channels here, beforethe only way are modified cards. . .
please explain how to test a dragon card with the apropiate firmware to check is this works here,i can post streamlogs too. keep in touch.
Cuco -
Originally Posted by Bill Gates
that you must program the CAM with a CAS interface from duolabs.
The firmware can be downloaded from my site www.the-lighthouse.se
stars.... -
@cuco: The infos you ask may not be legal in some countries and because this is an international forum, we can't talk straight for those issues.
Most of us in Europe, use Dreambox receivers to watch Videoguard cards outside the official recievers. There are also same Common Access Modules (CAM) that do the trick: Dragon CAM, T-Rex Cam and Diablo Cam are the most usual.
Last year's "Giga" CAMs reported that do the trick, so some very expensive HD DVB receivers, like NanoXX, Ferguson, SAB, Kathrein and Technomate. I can't confirm personally this.
A third alternative is with the combination of ProgDVB, the reported NDS plug in, a phoenix smart mouse (better serial, not USB) and a PCI DVB card for your PC. Here in Europe, the most popular PCI DVB card, is SkyStar 2.
For more infos, you have to google. -
But the Nanoxx is a very expensive HD receiver?? Its a Vantage 6/7k clone. Mh, the Technomate is a Clarke-Tech clone, the Kathrein HD receivers are buggy crap, SAB (no info on them yet) and Fergusson is using some OEM stuff and coding the software in poland... I'll trace for "giga".
Most interesting to me is the 3rd alt.
Thanks! -
@[_chef_]: DVB S2 receivers compared the DVB /S receivers are 3 - 6 time the price!
I mean, you can get a DVB /S receiver for 60 euros or less. The cheapest DVB S2 reciever I know is that "Dark Box" on, which is the official receiver of the Alabanian HD channels of the Digitalb package
So, they are "very expensive", same way BluRay players are very expensive compared DVD players.
SAB is a clone of ON LIEN (or the opposite, who really knows...)
fk, 3 years ago, the only way to get an official NDS card, without their own receiver, was to show to Viasat that you are also subscripted to Canal Digital Nordic.
Because of the E.E. laws, when 2 or more digital subscription services broadcast on a country, must somehow became compatible. There are 2 ways to succeed this: Or by broadcast on simulcrypt (there own code system and the competitor system) or to give only subscription cards, so to use them with C.A.M. on receivers with C.I.
That's why an official NDS Common Access System device exists in your Scandinavian countries. Of course, only few gonna pay for 2 subscription services, so the demand for those modules is low. On the other hand, they won't tell you that this is possible, so to force you to buy / rent their equipment.
The laws exists, so the alternatives. The problem is that the providers won't tell you about those alternatives and those laws. And if you know about them, and ask for your rights, it may take time to find your right. Meanwhile, you won't watch their TV Channels and that situation may take months. That's the reason the typical costumers bypass his rights to own a card only and choose to buy / rent the official equipment. Nobody waits for a card only. -
Viasat in there Canal digital box. Most Visat subscribers were offerd a new reciver or firmware upgrade but I have never heard about NDS cams. The picture of the CAM, you got is from an english site " leffe " something.
I dont know exactly how NDS works (and there arnt many) but I think there are differnt "dialects" of the encryption system so if one NDS system is hacked the others will still be safe. There for the tv providers wants to sell/rent
a spefic reciver to there customer so it will function the right way.
When the emu gbox (dreambox 7000s) with NDS support was released, the autours were freaten to there lives by
some tuff guys (maybe NDS people) so they stopped there development for some time....This indicates that
there are some big money behind this... And strangely the dreambox 7025 internal card reader have problems reading the NDS card (problem with the data transfer speed) so some is using a phoenix
interface or an usb card reader instead... (maybe this have been solve by a frimware hack)
regards stars..... -
@SatStorm,
kinda that is, thanks.
The cheapest HD DVB-S2 receiver I have seen so far without subscription etc. is €119 at anixehd.tv ...
h**p://shop.anixehd.tv/product_info.php?info=p586_Comag-HDTV-Sat-Receiver--HD-S-CI-100.html
@stars,
please be aware that a NDS CAM (Viasat) is nothing related to that encryption BSkyB is using...they are really different. -
Hallo,
Where can I buy NDS Videoguard subscription card to watch in Bulgaria Fox News at Astra 2B-28.2E, 12070H/27500. Is it necessary to buy original receiver with card, or is possible to use another one with card reader. Some links for card and recommendations about suitable receiver will be usefull. Thanks in advance.Ferguson FX 6600/+Octagon SF318 soft/, 1.2m motorized dish -
Originally Posted by pp46
then you have to buy a Skybox with the Subscription....... -
@pp46: Better try to watch FOX news from Sky Italia on Hotbird, or D+ on Astra. For Hotbird 80cm dish is enough, for D+ you may need 1.80cm.
By difference, the cheapest alternative, is ADD on Nilesat 101 at 7.0°W, but I don't know if this satellite is possible to be received in Bulgaria. In North Greece, we need 1.50cm dishes, so in Bulgaria, on the South part of your country, it might be possible with a cheap "Mabo" 1.80 offset.
The ADD package is less than 120 euro per year. -
Thank You chef and SatStorm. No problems with 1.2m dish at 12070, Astra2(28.2E) - abb.30% signal quality margin. I'll try Nielsat as well.
[quote="SatStorm
[/quote]
Hi SatStorm,
I saw you are based in Greece and using Hellas satellite. I am using a DTH service (named DOLCE) provided here in Romania by Romtelecom which is owned by OTE. Of course, is using the Hellas satellite and Videoguard encryption and officially it cannot be received with other receivers than the ones sold by the provider. Can I use a Dreambox (I am very interested in using a PVR enabled receiver) with one of the CAMs you mentioned in your post? -
Thank You mihaimihai.
Mihaimihai, here in Greece we don't use Hellasat 2 that much, we use Hotbird.
And OTE is now owned by Deutche Telecom, so Romtelecom is a part of the DT group now...
I don't know 100% about Dolce. Sky Digital (UK), Sky Italia and Viasat (Scandinavia) all work with Dreamboxes and T-Rex/Dragon or Diablo C.A.Ms.
But if you ask me, Duolab's Q-box is your best shot on this -
[quote="SatStorm"
But if you ask me, Duolab's Q-box is your best shot on this[/quote]
@SatStorm thanks for your answer! I would rather prefer to stay away from a computer+receiver, I want a device with all included, the tuner+HDD+CAM+software and I consider the Dreambox or other similar receivers as the solution. I need advice what to choose from the large offer of such devices (receivers and CAMs) and the biggest problem is that I don't have the required time to browse all the forums!
Regards,
Mihai
Alternatives to DVDfab?
By MrMcD in forum DVD RippingReplies: 11Last Post: 27th Apr 2012, 07:24 -
phone to use in europe
By MJA in forum Off topicReplies: 3Last Post: 7th Nov 2011, 17:13 -
Videoguard NDS & YES
By joni2000 in forum DVB / IPTVReplies: 3Last Post: 17th Aug 2010, 05:51 -
Alternatives to Toast
By danielmak in forum MacReplies: 6Last Post: 16th May 2010, 23:37 -
Which is 'best' of 4 Alternatives, VCR to PC ?
By netmation in forum Capturing and VCRReplies: 10Last Post: 1st Jun 2007, 08:43
