I have VOBs I need to convert so I can author and Burn to a DVD.
However, i don't have the IFO files.
I've used Magix Movie edit pro, DVD2AVI, Virtualdubmod, DVDshrink....
all with no success. They either produce screwed up video/audio or out of synch video/audio.
Tmpg plus seems it will produce an m2v/wav, but where do I go from
there? Plus each VOB is approx. 18min and it was taking over an
hour to process! So I aborted.
I just want to convert to an AVI or MPEG2 (DVD)
P.S. does converting to 23.97 / 29.97 affect the speed of the video?
If so, which slows it down, which speeds it up?
Take the VOB files and make them a DVD with Tmpg DVD Author. You'll have to choose "add video files" which will make the program look for mpgs, avi, etc. Just use the drop-down menu in the search box to "all files" and choose the VOBS.
This might help:
http://members.dodo.com.au/~jimmalenko/test.htm#ifoedit
Put each VOB in its own folder, then this will create the IFOs and stuff for you as if each VOB was a DVD by itself. You can then import each one into TMPGEnc DVD Author (30 day fully functional free trial) using the Add DVD Video button and author away.If in doubt, Google it.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
