Results 1 to 9 of 9
  1. My system is infected with this kind of virus. I have zonealarm antivirus and can't delete nor repair nor quarantine this virus. It says I need an archiving software to get rid of this. Does anybody know what or where I can get this archiving software? Thanks.
  2. Just downloaded and installed secura archiver. Tried to open this virus win32.identdhack , filename system volume information and add it to the archive for deletion but is unable to open file. What shall I do next? I don't want to reformat my hd. Any help please...
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Have you tried using the free online virus scanner at trendmicro.com? If not try using it to scan your pc. Also you could download and install FREE AVG antivirus software.
    Apr 2004
    Miskatonic U
    I would try Avast home, it is much better than AVG in just about every respect, and in my experience, picks up a lot more trojans and infections than AVG. It is licensed free to home users
    Read my blog here.
  5. Thanks guys. I'll give it a try.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    AVAST will catch it -- it is not seen by all virus programs though - see this test (not all programs call this by the same name)
    This is a report processed by VirusTotal on 08/11/2005 at 17:35:03 (CET) after scanning the file "ntuser.exe" file.
    Antivirus Version Update Result
    AntiVir 6.31.1.0 08.11.2005 BDS/Iroffer.14b2.B
    Avast 4.6.695.0 08.11.2005 Win32:Trojano-1333
    AVG 718 08.11.2005 no virus found
    Avira 6.31.1.0 08.11.2005 BDS/Iroffer.14b2.B
    BitDefender 7.0 08.11.2005 no virus found
    CAT-QuickHeal 7.03 08.11.2005 no virus found
    ClamAV devel-20050725 08.09.2005 no virus found
    DrWeb 4.32b 08.11.2005 no virus found
    eTrust-Iris 7.1.194.0 08.11.2005 no virus found
    eTrust-Vet 11.9.1.0 08.11.2005 Win32.Identdhack.A
    Fortinet 2.36.0.0 08.11.2005 suspicious
    F-Prot 3.16c 08.11.2005 no virus found
    Ikarus 0.2.59.0 08.11.2005 no virus found
    Kaspersky 4.0.2.24 08.11.2005 no virus found
    McAfee 4556 08.11.2005 no virus found
    NOD32v2 1.1191 08.10.2005 no virus found
    Norman 5.70.10 08.11.2005 no virus found
    Panda 8.02.00 08.11.2005 no virus found
    Sophos 3.96.0 08.11.2005 no virus found
    Sybari 7.5.1314 08.11.2005 Win32.Identdhack.A
    Symantec 8.0 08.10.2005 no virus found
    TheHacker 5.8.2.085 08.11.2005 Trojan/Small
    notice McAfee, AVG and Symantec dont even see it ...
  7. I'm back. Tried avg to scan my system and says no virus found. Tried avast and found viruses. Moved to virus chest and deleted infected files. Shall I delete also the system files in virus chest? Thanks.
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea as i said above , AVG will not catch it .. worthless to even try ..
    might as well delete system files in chest and then do a system file restore if nessessary
  9. Thank you guys so much. Scanned with ZA again and the virus is gone.
