  1. Most all DivX I get are 25fps or like... when I encode with TMPGEnc I select an NTSC template with 29.97fps seems to work well enough for me... but when encoding the same DivX files with CCE SP 2.5 I don't see how I can choose NTSC. Is this possible to do before I load into CCE without getting the audio synch problem? I just wanted to compare TMPGEnc and CCE.
    Feb 2001
    Berlin, Germany
    You know CCE isn't as feature rich as TMPG. CCE comes with almost zero filters. TMPG changes the framerate if you like, save a TMPG project, convert with VFAPI, load as videosource into CCE.
    Or change the fps with Avisynth / VirtualDub and frameserve to CCE.
    There were several "change framerate" topics the last days, use the forum search.
