I'm using DVDLab Pro to author my dvd. I was wondering if its possible to set the subtitle position on the letterbox. The blackbars instead of the subtitles showing on the display screen. Since the blackbars are there just for the aspect ratio I was wondering if I can display subtitles on it with DVDLab Pro
I dont know, never had to figure if it can do that yet but you can use Subtitle Workshop to change the location of your subs. If soembody else has the answer your looking for great, but if not, I would be doing this if I had too.
Quality is my policy. -
If I do it in Subtitle Workshop how would it save? does it change my srt file to something else or it will be the same file format but with different positioning. Or do I have to encode my video again with the subs?
"Save as" .srt (subrip), in same format with different positioning. Author with subs, then check when finished to see if its to your liking.
Subtitle Workshop will save in just about any text or sub stream extension.Quality is my policy. -
I downloaded the program and I can't seem to find how to change the position or location of the subs displaying
Correct. It doesn't. .SSA does, tho, but I'm not sure DVD-Lab does .ssa, and if it does, if it respects the positioning.
/Mats
How to position a subtitle in a .srt file ?
By momo1984 in forum SubtitleReplies: 24Last Post: 24th Feb 2019, 05:01 -
subtitle position with aviaddxsubs
By marioval in forum SubtitleReplies: 3Last Post: 27th Feb 2011, 20:15 -
Subtitle Position
By Abas-Avara in forum SubtitleReplies: 9Last Post: 25th Mar 2010, 16:09 -
Wont let me change subtitle position.
By anarchyx34 in forum ffmpegX general discussionReplies: 1Last Post: 16th May 2009, 01:14 -
adjust dvd subtitle position
By pcb in forum SubtitleReplies: 1Last Post: 27th Aug 2008, 19:42
