Can someone help me I want to put 3 movie files onto DVD they are windows media files and I want to play it on my DVD can some help me and tell me is there any instructions to AVIcodec anywhere
Thanks in advance for the help
try some wmv to dvd tools, https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=WMV+to+DVD&...+or+List+tools
Originally Posted by drew23977
In short, you need to convert to DVD-compliant MPEG, then this MPEG needs to be authored, to create IFO, BUP and VOB files. There are tools in the tools section that can do both these things in one step (and almost one click), or there are dedicated tools to do each step seperately.
Here's some reading that may assist you:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=WMV+to+DVD&h...or+List+Guides
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
https://www.videohelp.com/tools?s=35#35
https://www.videohelp.com/tools?s=40#40
Originally Posted by drew23977If in doubt, Google it.
Copying separate files from dvd's
By Peter1954 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Dec 2011, 07:15 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
Strange problem - zero length files *only* after copying to DVD
By GregSchmidt in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2010, 11:05 -
Problems copying VOB files from DVD to PC
By jaekim86 in forum Newbie / General discussionsReplies: 8Last Post: 19th May 2009, 02:09 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30
