  1. hi all, this may be beyond newbie but i have a question:
    i used a AVS Video to transform a file from AVI to DVD and the files created was .VOB. And then i was using Cucusoft and i converted an AVI to DVD and the output was in .mpg so i was wondering wich is the real DVD extension.
    -----willy_johnson_54 WAS HERE-----
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    A DVD is made up of Vob files. Read the link below for more info.
    https://www.videohelp.com/dvd
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    VOB files are authored MPEG-1 or MPEG-2 files.
    https://www.videohelp.com/glossary?A#Author
    If in doubt, Google it.
  4. Member daamon's Avatar
    Melbourne, Oz
    VOB files contain the .mpg files and the audio (if it's not in the .mpg file), as well as other stuf flike menus and subtitles.
    As jimmalenko said - authoring takes .mpg files, and / or .m2v and audio (MP2, AC3 or WAV), menus, subtitles, chapter point info etc. and bundles all this up into the VOB files.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. cucusoft avi to vcd/dvd output the dvd as a program stream.
    use cocusoft mpg to dvd burner to burn the file
    http://www.tomdownload.com/multimedia_design/video/cucusoft_mpeg_to_dvd_burner.htm
