  1. If I were to replace my 17 inch crt monitor with a new flat screen so that the video editing I do shows as near as possible what will show on my dvd player to my tv, which computer monitor should I get?
    As we know this is a regular issue raised, and I am hoping I can solve it.
    Thanks for your advice.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Computer oriented flat screen LCD's are very different in color response to a TV and shouldn't be used for quality judgement. They are OK for edit decisions.
    A true video oriented LCD is an expensive beast currently.
    http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=2199
    Vegas 6 added support for this type of LCD monitor.
    CRT video monitors are by far more affordable.
    http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=1981
    A quality HD Ready TV (in 480i/576i mode) makes a good poor man's substitute.
    Next best would be to use a LCD TV that has TV gamma and black levels.
    http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=2500
    Most cheap LCD TVs are just computer panels with a TV tuner and have poor blacks.
    http://www.kiva.org/about
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Depends to what exactly you are referring...are you trying to compare image color/sharpness, screen size, output dimensions?
    Google is your Friend
