Hi there
I having problems creating DVD movies, I manage to burn the movies onto DVD disc but my DVD player cant play it and my PC wont recognise the DVD disc does anyone know what i am doing wrong? or suggest anyway of solving it ?
I m using DVDSanta to burn the movies onto disc and im using x8 Speed Verbatim blank discs but im only burning that at x4 speed as that it is the highest speed my dvd burner does.
thanks for your time
Try using DVDshrink and DVD Decrypter.
Life is like a pothole, you just have to learn to get around it. -
Hi there thanks for a reply
i just tried it there using DVDshrink and DVD Decrypter and i get the same result.
anyideas why it does this ? is because the blank DVD are x8 speed ? -
Probably should fill out your profile so people can see your burner brand. Might check the DVD media link to your left to see if others have had trouble with the verbatim disks and whatever burner you're using.
Had similar problems with my burner and was told to check cdfreaks for news about firmware upgrades. Firmware upgrade helped me a lot. Your results may vary.
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
Making movies with chapters
By dw1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 08:53 -
Making Movies is More difficult than I thought
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2008, 02:16 -
Making My Movies Into ISO File
By imdaman in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2007, 21:06 -
Nero 7 is making movies bigger than they should be...
By Harkonnen in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 02:59
