Results 1 to 9 of 9
  1. Well, after several blue screens I decided to format. First, it would let me as far as the delete partition part of it then ANOTHER blue screen. Didn't know I could get them from setup. The I got as far as actually formatting and about 10 percent of the way through, and ANOTHER blue screen. SO...now I can't even format. Would this be an indication that my HD is fucked? Or should I do something else?
    I'm using my girls PC for now, until I get some good advice...help
    SmileSmile
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    What brand is your hard drive? Maxtor, Western Digital and I think Seagate have utilities to check the hard drive for errors/failures. I had a similar problem when reformatting a compaq pc. I didn't get the bsod but the hard drive took over 1 hour to format. I figured something was wrong and used the powermax utility from maxtor and sure enough the hard drive was failing.
  3. It's some old cheap IBM drive...not sure exactly. I don't have any disks for it. I'm just wondering if it's possible that this could be anything other than a HD problem. While waiting for replies, I turned off the PS and cooled down the system a bit. After, it got to about 80 percent before giving me a blue screen....damn
    SmileSmile
  4. Anonymous
    Guest
    I'm having a similar problem.I was able to format but not able to get a fulll install.Will I be able to install win xp from a recovery disc on a new drive?
  5. Banned
    Sep 2004
    Inner Circle of Thought
    Is your install disc scratched?
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    IBM hard drive? Deathstar? Oops I meant Deskstar! As already mentioned your disc could be scratched. If you have a spare hard drive try using it with the disc then you can rule out if it's actually the disc (scratched).
  7. Originally Posted by budz
    No, the disk isn't scratched. I keep everything pretty clean. However, I did EVENTUALLY manage to get windows on my PC, but I have no idea how. The blue screen just never came
    SmileSmile
  8. i had a similar problem, trying to install xp it seemed it didn't like it when i formated the hard drive into fat32, i used partition magic to make just a black hard drive non formated. then xp formated it itself and it liked that better.
  9. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Glad to hear you finally got windows installed. Sometimes installing windows is such a bitch!
