Does anyone know if there are any USB to S-Video/Composite video OUTPUT adapters/cables out there?
My new laptop is pretty basic and just has USB2 and a VGA ports on it. I'd like to watch DVD's or other video files in my PC on my regular TV set.
My old laptop had a built-in S-video out jack on it, so it was not an issue.
I know there are many S-Video to USB INPUT adapters all over the place, but I need something that goes the other direction - just outputs S-video via the USB port.
I have seen USB2 to VGA adapters out there that allow you to run a second monitor without buying a new video card, so I figured it might be possible. My understanding is also that some higher-end hardware-assisted capture devices (eg. ADS USB Instant DVD 2.0 has a TV preview option I think means its bidirectional and lets you output your edited video file to a TV to view) can do this, but its way more than I need.
Just wondering if a simpler option exists and I just missed it in my search.
AD in Canada
Aug 16 2005
Here is something that may be suitable. It converts your VGA output to composite video and S-Video output. It draws power from your USB.
GRANDTEC GEZ-1000 PC-TO-VIDEO CABLE
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
The eazy way is with VGA to S/Video or RCA Adapter you need check your Video Card manual or manufacturer to make sure that your VGA card has TV-Out function capability through the VGA connector to ensure that cable this will work for you.
Easy Cap USB 2.0 Video Adapter
By Joy123 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2011, 07:53 -
USB to DVI Video Adapter?
By lenny_67 in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Mar 2010, 11:24 -
How to transfer video from Hi8 camcorder without USB output
By vd0m45ter in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2009, 06:50 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18 -
help, does a USB to coaxial converter exist?
By delt_o in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2007, 17:56
