http://www.14wfie.com/global/video/WorldNowASX.asp?playerType=native&ClipID1=499583&h1...0for%20Tuesday
this is the direct link. 'saving as is' only saves it in a ASP extension. I used several programs like Snag It, Cam Studio, and Image Grab neither work and only record a black screen. any ideas?
If you install Net Transport , it will give you a right mouse button addition to your context menu - "Download By NetTransport" , if you right click on the link you gave it will do all the parsing of the url for you , tell the program where you want it saved and click OK , then it`ll download the wmv file for you .
As a sidenote please quantify what isnt working , is the program not starting or does it throw up an error or not connect ?
As a guess , I take it you havent put a URL into it ? go to the asx file you downloaded and rename its suffix to .txt , open the file and take a look inside and copy the bits inside the inverted commas and paste them into WMRecorder . Or install Net Transport and let it do it for you .
If you dont know what a URL is , then google it .
Capture and record video directly to DVD
By ruslenko in forum Capturing and VCRReplies: 8Last Post: 9th Oct 2010, 08:47 -
Cannot capture video from website
By Keys767 in forum Newbie / General discussionsReplies: 6Last Post: 20th Aug 2010, 21:12 -
Question about best way to capture/record BBC Proms website
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 15th Sep 2009, 21:27 -
Can someone please go to this website and assist me to capture video
By jimdagys in forum Video Streaming DownloadingReplies: 4Last Post: 28th Jun 2009, 04:41
