What authoring software would you use and how would you do it? I have the Nero burning rom suite but no Nero Vision Express. I'm an avid golfer and want to capture some on DVD. I understand I'm going from 1080i to 480i and that I can't preserve the quality. Is there any freeware?![]()
Software-EAC/AccurateRip/APE
J River Media Center 11
Cinemar MainLobby,DVDLobby and MusicLobby -
Hi-
I'm having trouble understanding just exactly what you want to do. If you're making compliant DVDs for playback in standard DVD players, then it has to be resized to 720x480/576 and reencoded anyway, and any authoring program will accept the result.
If you're keeping it Hi-Def, then if it's AVI, WMV, MPEG-2, or TS, the DVD/MPEG-4 players with the new Sigma Designs chipset can play them:
https://www.videohelp.com/dvdplayers?chipset=Sigma%20EM8620L
Maybe I'm misunderstanding, though. -
AviSynth can help. Here is my script:
Code:# HDTV .ts conversion (1920x1080i) # # First load the .ts file into dgIndex and save project. # This will give you a .d2v file and an .ac3 file. # Then load the .d2v file using the below script. # Remember any cuts you make in the video will de-synch # the audio. loadplugin("C:\Program Files\AviSynth 2.5\plugins\MPEGDecoder.dll") vNTSC=MPEG2source("c:\video\work\bonjovi.d2v").cropbottom(8) #return v #full HD resolution return v720x480i(vNTSC) #return v720x480p30(vNTSC) # Converts 1920x1080i to 720x480i anamorphic function v720x480i(v) { # deinterlace the video v=bob(v) #Separate fields and interpolate them to full height # resize and reinterlace v=v.BilinearResize(720,480) #v=v.SeparateFields.SelectEvery(4,0,3) #even field first (BFF) v=v.SeparateFields.SelectEvery(4,1,2) #odd field first (TFF) v=converttoyuy2(v) #corrects YV12 artifacts v=weave(v) #re-interlace return(v) } # Converts 1920x1080i to 720x480p at 30 fps function v720x480p30(v) { v=bob(v) v=AssumeFrameBased(v) v=v.BilinearResize(720,480) v=SelectEven(v) return(v) }
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 19:56 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
*&@! Comcast!! No more broadcast HDTV over QAM?
By zephxiii in forum DVB / IPTVReplies: 19Last Post: 8th Aug 2007, 07:02 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
