Closed Thread
  1. Im having problems joining 2 avi files using vdub .
    Im getting the message about vbr codes and different audio streams sample rates . Im going to try running them through TMPEG to convert to mpeg then join them .
    idont know if this will work but will try it until someone has time to help me.
    Thanks.
    Apr 2004
    Miskatonic U
    Joining avi files often results in audio sync issues int he second half. As you have tmpgenc, encode each seperately. Use tmpgenc DVD author (there is a fully functioning 30 day trial) to author both sections to a single title. There may be a slight join in playback, but no worse than a layer break.
    Read my blog here.
