Hello,
I'm looking for an alternative way to convert my PAL DV tapes to DVD-Video. Currently I'm using Toast 6 on my 900MHz Power PC G3 ibook with 256MB RAM running OS10.2.8 to import the DV, convert it and burn the disc. The result is fine, however it takes approx 30 hours for a 1 hour tape which is quite frustrating. I'm considering buying a DVD Recorder & doing it that way but I'd rather do it on the computer so I'm researching software encoders (can't find any hardware products that will work with PAL on a G3). I'm wondering if anyone has any experience using ffmpegx on a G3 to convert PAL DV to MPEG2 for making DVD-Videos? Any ideas about how long ffmpegx will take to convert, let's say, 1 minute of PAL DV to good quality MPEG2? Doesn't matter if it's muxed or demuxed or what kind of audio it creates. I've got tools to deal with all the possible final file types and the burning. Just need something to convert my PAL DV into a good quality MPEG2 faster than 30 x real time. Much faster hopefully. Thanks. Take it easy.
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 08:10 -
Does anyone got idea to encode VC-1 to Mpeg2?
By Dboyz in forum Newbie / General discussionsReplies: 2Last Post: 3rd Sep 2009, 09:07 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 18:21 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 01:54 -
Playback of PAL DVD at correct speed ?
By MacEachaidh in forum Software PlayingReplies: 2Last Post: 19th Sep 2007, 01:02
