I'm about to purchase a DVD writer and after some research I have now narrowed it down to these two models. Any thoughts or comparisons? Pluses or minuses of each model? Better yet, has anyone used both and can offer any opinions on which might be a better choice and why?
Results 1 to 17 of 17
I have both. the 109 is good for everything except 16x pure CAV media such as TYG03s. It tends to lock up during leadout on this type of media. Pioneer has made no effort thus far to fix the problem and with the 110 hitting stores they likely never will.
The 3520 is also a good burner all around. It tends to favor +R media but does fine on -R as well. I've personally had a few problems with leadins on the same kind of media the 109 has issues with but I think that may be a software problem in this case. Overall the NEC tend to give better results on +R while the 109 gives better burns on -R, when it burns correctly. -
Thanks very much for your response. Anyone know if the CAV issue is also apparent in the new 110? The 110 doesn't seem to have changed much at all from the 109 so I'm not big on the idea of spending more for it.
I haven't been keeping up with it as much in a while now. Check out the Pioneer forum on cdfreaks.com for your best info.
I wouldn't purchase either one. A better choice would be between the NEC 3540 and the Pioneer DVR-110D. I've had the new Pioneer for a few days now and think it's a great writer. I wanted good writing quality on quality media (TY) and the capability to import DVD-RAM for editing and burning to DVD-R.
Your needs and priorities may be different but at less than 60 Bucks delivered to your door you can hardly go wrong with either.
Good Luck! -
Any idea if the 110 handles TYG03s and other 16x pure CAV disc okay, unlike the 109?
I have not tried TYG03 yet.Originally Posted by Poppa_Meth
Have you seen this:
http://pioneeraus.com.au.us.server-fast.com/media/downloads/DVR110D_Media_List.pdf -
Only 5 DVD-R MIDs and 5 DVD+Rs MIDs supported at 16x. Also only one 8x DVD+RW MID supported at 8x.Originally Posted by steven2874
No wonder media manufacturers start using fake media codes when there are drive manufacturers such as Pioneer around... -
Anyone know if the NEC 3540 can read DVD RAM? On newegg it doesnt list that it can, but it also doesnt list it for the Pioneer 110 either but I assume it can considering Steven's post?
The PIONEER does, the NEC does not.Originally Posted by ann coates
Keep in mind that this model does not WRITE DVD-RAM. This is rumoured for a future model or perhaps a firmware upgrade. -
I think Pioneer's thinking is to support 16X writing on quality media.Originally Posted by -jsl-
8X DVD+RW Media is only recently introduced. -
Thanks Steven. I'm going to go with the Pioneer 110D.Originally Posted by steven2874
Good luck, Ann! Let us know how you like the writer.Originally Posted by ann coates
The "First Class Media" in Sony, Maxell, Taiyo-Yuden, TDK and MCC are supported. Do you think it is mere coincidence these media codes match exactly with those found on NoMoreCoasters? Why use anything else?Originally Posted by -jsl-
If they supported crap like 16X CMC or InfoSmart and someone's brand new DVR-110D started shooting out coasters, why should Pioneer have to fend a bunch of phone calls from disgruntled customers because of crap media? Do you think the average Joe would complain to CMC or to Pioneer?
How many different QUALITY 8X DVD+RW media makers are there?Also only one 8x DVD+RW MID supported at 8x. -
The thing about the 109 is that TYG03s are indeed on their supported media list. So are the verbatims that many people have the same issues with. Not the best support if it's buggy. Besides it's not the media in that case but the drive itself. I'm assuming the 109 must have a hardware problem. If it was firmware I would think they'd have fixed it by this point. Regardless, I'm not planning on buying another Pioneer again. Not because they are bad drives, but because when there is a problem they aren't willing to do anything about it.
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 05:19 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 05:44 -
Internal drive Pioneer 18 x versus Philips 20 x
By coody in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Oct 2007, 14:31 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 15:03 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 09:48
