I just built a PC for my girlfriend. All is going well with it, except for sometimes the mouse, which is a Razor Diamondback, doesn't detect on boot up. The keyboard and mouse are both USB and the keyboard detects fine. 1 out of 5 times though the mouse will not detect and I have to reboot it to get it to pick up. I checked the Bios and USB Keyboard support is enabled but USB Mouse support is not. I tried changing that with no luck. Any ideas what to do. I'll post the parts here in case that will help.
AMD Athlon 64 3000+ 1GHz FSB Socket 939 Processor - Retail $146
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537
CHAINTECH VNF4/Ultra ATX AMD Motherboard - Retail $84
http://www.newegg.com/Product/Product.asp?Item=N82E16813152049
Antec Life Style SONATA Piano Black Computer Case - Retail $70
http://www.newegg.com/Product/Product.asp?Item=N82E16811129127
CORSAIR ValueSelect 512MB 184-Pin DDR SDRAM System Memory - Retail $47
http://www.newegg.com/Product/Product.asp?Item=N82E16820145026
Seagate Barracuda 7200.7 80GB 3.5" Serial ATA150 Hard Drive - OEM $65
http://www.newegg.com/Product/Product.asp?Item=N82E16822148040
NEC Black IDE DVD Burner Model ND-3540A - OEM $42
http://www.newegg.com/Product/Product.asp?Item=N82E16827152047
SAMSUNG Black Internal Floppy Drive Model SFD321B/LBL1 - OEM $12
http://www.newegg.com/Product/Product.asp?Item=N82E16821103203
Saitek Black Wired Eclipse Keyboard - Retail $54
http://www.newegg.com/Product/Product.asp?Item=N82E16823175103
SAPPHIRE 100595 Video Card - OEM $127
http://www.newegg.com/Product/Product.asp?Item=N82E16814102443
Microsoft Windows XP HOME Edition With Service Pack 2 -OEM $93
http://www.newegg.com/Product/Product.asp?Item=37-102-151&DEPA=6
Monitor Envision EFT720 Black/Silver $120 at Staples.
1Z4785W00359282190
Thermaltake IDE Round Cable - Retail $10
http://www.newegg.com/Product/Product.asp?Item=N82E16812183033
Razer Plasma Diamondback Black Mouse - Retail $60
http://www.newegg.com/Product/Product.asp?Item=N82E16826153104
Results 1 to 9 of 9
I ran into that problem with my laptop. Fortunately the optical mouse came with a USB to PS2 adapter and when I use that, the mouse works perfectly all the time. Just plugs into the PS2 mouse port instead of the USB port. I have no idea why it works this way.
I suspect it has something to do with the order the drivers load.
You might be able to get one with a cheap mouse, or check a computer shop and see if they have a spare. -
I don't think this mouse works with a PS/2 adapter. I'll try it, but it draws more power than most mice because is has more lighting inside it. I have a feeling that it'll require the extra juice from the USB. I don't think it can achieve it's maximum sensetivity via a PS/2 connection either. I might try changing which port it's plugged into the next time I'm at her house and see if that helps.
Personally I'm not too found of USB mice and Keyboards but that what she insisted on because it looked cooler. -
You're right. The Razer site says it won't work with a PS2 port.
This was also on their site.
Q. Sometimes my Razer mouse does not work at startup after a cold start?
A. Make sure your ports are not going into hibernation mode. Check the following:
- Right click on the My Computer icon and choose Properties.
- Click on the Hardware tab.
- Click the Device Manager button.
- Click on the + sign next to Universal Serial Bus Controllers.
- Right click on any Root Hub and choose Properties.
- Click the Power Management tab and make sure there is NO CHECK in "Allow computer to turn off this device to save power"
- Click the OK button and do this for each Root Hub.
- Next, click on Start and Control Panel.
- Double click on Power Options.
- Click the Hibernation Tab and uncheck Enable hibernate support.
Not so much the hibernation part, but the part that says "Allow the computer to turn off this device to save power." I notice that is checked in my computer. Maybe default?
BTW, if you haven't been to their site, a lot of FAQ's there. -
Yeah I just found that myself. I'm going to try it thursday and hope it works. It just gets annoying to her having the mouse not working like that. Mine was set to this by default as well. I'm assuming hers will be too.
I had this problem too, looks like it only occurs when you use the saitek keyboard with the razer mouse.
I think your comment about the power is correct, did you have any luck fixing it ?
I tried all the stuff of razer website and I even contacted them about it but they couldnt help me.
Any ideas or is it a bin job on the saitek keyboard ?
What about increasing the voltage in Bios would that give it more juice to work properly ? -
My USB mouse on my desktop sometimes (but not usually) loses power when the PC hibernates, and fails to regain power when it wakes up. Unplugging the mouse and reinserting it into the same USB port works every time. I suppose you have already tried this? It's more of a pain on my desktop PC because it's plugged in the back. That's why I didn't try it right away. It's way easier on a laptop, so I imagine you've already tried it, but I mention it just in case. Sometimes the simplest solutions work.
Yep but it only happens on boot up
if it fires upon startup it works and even on hibernation it will still work when I come back in.
the problem is sometimes it wont work on startup so I have to reach to the back of the pc and un plug and replug, its just an annoiance but when you spend £25 on a top line mouse you shouldnt have to do this
Mouse wheel timeline zoom problem with Vegas 11
By sdsumike619 in forum EditingReplies: 9Last Post: 7th Aug 2012, 15:57 -
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 04:25 -
Lifemedia Htpc IR and usb wirless mouse/keyboard conflicts
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Feb 2011, 20:56 -
PS/2 or USB for mouse & keyboard?
By Xylob the Destroyer in forum ComputerReplies: 11Last Post: 9th Feb 2008, 10:23 -
Mouse problem
By yogart in forum ComputerReplies: 2Last Post: 24th Jun 2007, 05:40
