  1. Hello all, i want to convert Avi to Mpeg to copy to DVD for TV playback.
    How dfo i do this please?
    I have got the latest Nero, XP media edition computer. 3.2GHZ Pent 4, 1GB Ram 2 x 186 hard drives.
    Can you explain what programs i need, and how to go about it.
    Thanks in advance, Gepuk2001
    Apr 2004
    Miskatonic U
    How much time and effort do you want to put into this ?
    If you want to learn the details and have as much control as possible to try and get the highest quality possible, then I would suggest
    avisynth or virtualdub for filtering and resizing
    CCE Basic or Procoder Express for encoding (Tmpgenc is also good, but for my money prohibitively slow)
    Photoshop for menu prep (still menus)
    DVD Lab Pro for authoring if you want to get complex, tmpgenc DVD author for simpler menus
    If, on the other hand, you just want to get your avi onto DVD with reasonably good quality (no worse than the original avi) and with minimal effort, and you don't want menus, VSO DivxtoDVD is probably the best one-click-wonder available
    Read my blog here.
  3. Hello Guns1inger, thanks for the information, i will try it out.
    GEP
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    WinAVI will do what you want...not the highest quality solution...but it works.
    Google is your Friend
