Hi
I'm new to this site, so hello to all.
I have a very basic question. I'd like to be able to lower the resolution of mpeg2 movi files from 480x480 to maybe half the size. I downloaded the TMPEGEnc MPEG Editor trial version, which is fully functional for 14 days. I used that to edit the mpeg file and remove unwanted frames. However it does not give me the option to change the resolution. Is there a good software that allows lowering resolution?
For resize you will need these tools: TMPGEnc Xpress or TMPGEnc Plus
Resize to 352x480 using Lacsos-3
Converting HD (1280x720) to lower resolution for YouTube
By arjanpublishing in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 31st Dec 2009, 11:17 -
Frame resolution is suddenly much lower when capturing?
By dimitri_vdh in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 16:48 -
Bigger file with lower resolution after conversion???
By unplug in forum EditingReplies: 6Last Post: 20th Aug 2008, 16:09 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
mpeg2 to mpeg2 lower quality...
By zovx in forum DVD RippingReplies: 4Last Post: 6th Feb 2008, 16:36
