I made a dvd with 1 movie that is cut into smaller parts...all of the moveis are connected, so when one finishes it goes to the next...but is there a way to use the "next" button on the remote to make it to the end of one movei?..in other words i want to be able to skip to the next movie....is there a way to do that?
I was thinking about just putting a chapter at the end of the movie but i was wondering if there was a "proper" way of achieving this
thanks in advance
The proper way, if they are part of the one movie, is to join them before authoring so you don't have this problem. If they are seperate episodes of the same story then a chapter stop on the last frame of each is probably the best way to go.
DVD Lab Pro also has a concept called Movie Segments, where you can put all the parts on a time line and they will author as a single title, but there is a catch. You get chapter stops at the start of each segment, but you cannot put chapter stops in between.Read my blog here.
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
Converting Home Movies (multiple formats) to x.264
By llmercll in forum Video ConversionReplies: 12Last Post: 24th Nov 2010, 11:42 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
how to burn multiple DVD movies in one DVD
By jedy in forum DVD RippingReplies: 3Last Post: 8th Apr 2009, 05:51
