I have a camcorder that records at 29.97 fps interlaced only. Is there a way to turn that into smooth 23.976 fps progressive, simulating film? I know regular inverse telecine won't work, as there are 60(or so) distinct fields as opposed to repeated ones and there is no pattern to recognize.
Do you know of any software or filters that can help me in this task?
Thanks for the help!
PS: I'm sorry if this has been discussed before, but I looked for it and really coudn't find anything!
What is the purpose? Transfer to film?Originally Posted by tokumaru
Best to keep it interlaced. The process to convert to 23.976 will degrade the video. Professionals can do a reasonable job if this is important.
If you are only looking for a film look at 29.97 there are many filters that simulate film look without the jerky-blurred result of 23.976 that many don't appreciate. Real film presentation isn't that jerky because a projector shutter repeats frames for an effective 48fps flicker.Originally Posted by tokumaru
Just my opinion.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Best framerate conversion? (eg: 23.97 to 30 fps to avoid judder)
By ionone in forum Video ConversionReplies: 16Last Post: 12th Mar 2014, 08:56 -
Skipping after Encode - Increasing Source Default Framerate the Culprit?
By DivXHead75 in forum Newbie / General discussionsReplies: 5Last Post: 15th Feb 2009, 20:54 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 01:00 -
Framerate conversion question - 30fps source
By Killer3737 in forum Video ConversionReplies: 17Last Post: 8th Aug 2007, 14:30 -
Framerate FAQ:60 fps vs 30 fps
By Breakpack in forum Capturing and VCRReplies: 1Last Post: 9th Jun 2007, 05:42
