the problem im having is i have 1 film that is split into 2 avi files when i convert it using svcd2dvd (v2) it don't join together properly how do i merge it so it plays the whole way through
I just completed the same process for Alexander and when I used Shrink to create dvd it worked fine.
Are you putting the two movies manually on the same TitleSet or using "Quick DVD"? If the later, are they in the same folder & do they have a common basename like move_part1, movie_part2 ?
Hi Chrissy,
I am having the same problem with your latest version that you sent me. Only I am getting error of not enough disk space. I have 14GB open, so I don't know what the problem would be. I too have two avi files for one film as an Xvid. Manually put the 2 avi files in titleset and started the processing. I don't have pulldown checked but I do have the merge titlesets checked. I also have autofit selected. It gets up to 92.9% completed on the 2nd avi file and then gives me the disk space error. I will try clearing more disk space tonight and uncheck merge titlesets to see if this helps. If you can think of any other suggestions that I can try, I will be attempting tonight after work.
Thx,
Fudgstu -
Well you could send me the log for review but 14 GB sounds ok on the working drive.
C.B.
No need to look further for problem. I was forgetting that 2 AVI files that were 7GB to AF to 4GB required an NTFS drive. I moved the files to the NTFS drive and started the processing. No problems with the conversion or any errors. Thanks again for your support.
Fudgstu
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 18:05 -
Svcd2dvd
By dobbin in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 24th Jan 2011, 12:19 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
Svcd2dvd
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Apr 2010, 05:55 -
svcd2dvd
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th Sep 2007, 12:34
