I'm using D2S ver. 1.2.2.3, D2SRoBa v3.78, CCE 2.67.00.27 und EclCCE 1.8.
So when i start the conversion, the whole process should run without any further activities from the user. But when D2S starts the CCE the Quality Settings Window always pops up. So i have to manually click apply and OK. After some seconds the Quality Settings Window will pop up again. So again click on apply and OK. Then it finally starts to encode, but not with the settings I made in D2S.
I tried the CCE 2.500 and it works perfectly but I wanna use the newer encode engine of CCE so anyone know a solution for my prob?
yes, buy the full version of CCE SP. If you can't afford it, you shouldn't be using it. There is always CCE Basic for $59, for us regular people. Cheap enough.
btw...CCE SP latest version is now 2.70.02.01, and CCE Basic is 2.70.01.04. Free updates for people who actually purchased the product. -
Guys, if you have no constructive advice to give, keep quiet. You can make whatever assumptions you like about the OP's source of CCE, but they are just that, assumptions.
And the fact that you seem to know so much about various cracked versions suggest you may not be as saintly as you make out
There are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by bugster
I didn't say I'm a saint.....
.......but I've seen numerous threads like this,people wondering why CCE acts this way,and the only version that does so,is the 1 I mentioned....
The only "constructive" advice I can give in this case,is to stop using it.....and stay with CCE 2.50 or use 2.67.00.23,instead of 2.67.00.27 ......
16:9 divx movie won't play properly on my TV
By romino in forum Video ConversionReplies: 4Last Post: 22nd Oct 2010, 07:36 -
MPG won't play properly in VideoRedo
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2010, 18:13 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 12:58 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 22:38 -
Can't get the .TS audio to work properly
By mkvbob in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 17:04
