I have had no problem capturing video from my Sony PC110 DV video camera for the past few years.
After installing a Hauppauge TV card, now I can suddenly no longer capture DV. I have tried taking out the TV card and I have no luck.
When I fire up Windows Movie Maker, I get a message "A video capture device was not detected".
I have tried plugging it into several 1394 ports but no luck. My other 1394 device, an external DVD writer, works fine.
Do I need a driver for my DV camera?
Results 1 to 12 of 12
http://www.kiva.org/about -
Do you have SP2 installed? It seems there are some people (like me) that have problems with their DV-Devices after installing SP2.
it's possible the firewire port on the camera got fried. you might want to try the camera on another computer, then have the camera checked out.
That might make sense. The camera will not work on either of my two computers' 1394 port.
I can capture video through my ADS Pyro link on both computers through the 1394 port.
The camera works fine other than that. Can the port be fixed? -
I have now some valuable information:
It seems that SP2 installs a new MSDV.sys and AVC.sys. Those files prevent the IEEE 1394 port to recognize the DV-Recorder correctly.
I found some help on the net how to replace those two files out of the driver.cab-archive back into SP2.cab (filearchive for windowsdrivers), but it did not work. Some others report that it worked..
I had to completely reinstall windows, first a format of the systemdrive, then a complete, clean installation of Windows XP without the servicepacks. Now it works fine again..
Microsoft doesn't have a patch for this problem ready right now, not for Win XP anyhow.. It seems that they have a hotfix for Millenium, though.
I guess you have to reinstall Windows and let it be in it's unstable, unsafe state as long as you want to capture DV...
I have no problem with that as this computer is not connected to the net, it's a videocutworkstation only.
I hope it's right what I wrote. This problem seems very new, only few report about that sort of problem.
Greetings,
Adrian -
Originally Posted by Adrian2k5
Can you better identify your motherboard, CPU and other machine characteristics?
My experience has been with Intel, Gigabyte and Via motherboards with Intel processors.Recommends: Kiva.org - Loans that change lives.
Try this
It worked for me no problem, might be your answer
https://www.videohelp.com/forum/viewtopic.php?t=252426Hmmm, time to kick ass and chew bubble gum....But am all outa gum. -
I have a DV camera and my firewire port is fried...apparently the panasonic pv-gs120 models had this happen quite often...for my model at least the firewire port is integrated onto the main board so the only way to fix it is to replace the whole board which costs more than buying a new camcorder :P. For regular everyday videos i just capture via s-video to .avi (raw or huffYUV) and then use TMPGEnc 3.0 Xpress to encode. The quality is still good. If I do an important video i just have to borrow my brother in laws camera and use the firewire out on it. I wanted to get a miniDV player but for some crazy reason they are outrageously expensive...why can I get a $250 dv camera that will playback miniDV through firewire AND record, but something that just plays costs $1000+???
Camera - IEEE 1394, Compsite and mic in???
By djlerman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Jan 2012, 23:58 -
Capture video from DV-camera and audio from soundcard
By NiQ in forum Capturing and VCRReplies: 1Last Post: 25th Mar 2010, 11:57 -
What are the advantages of using a DSLR camera for video capture?
By Wile_E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Jul 2009, 04:11 -
capture video+audio from IP camera
By mb508 in forum Capturing and VCRReplies: 5Last Post: 13th May 2009, 16:53 -
Capture from PC to Video Camera
By gamerscircle in forum Newbie / General discussionsReplies: 14Last Post: 4th Jan 2009, 12:21
