Have an iMovie DVD (VOB files) aspect ration 16:9. I want to letterbox the files so they will play undistorted on an NTSC TV 4:3. I can redo the entire movie in iMovie and it will do this - too much work.
How can I transform my 16:9 VOB files into 4:3 letterboxed VOBs??
I have MPEG Streamclip, ffmpegx, OSEx etc.
Any ideas would be appreciated
Typically a 16:9 DVD is automatically flagged to play letterbox on a 4:3 TV. You shouldn't have to do anything.
Download and open the freeware application myDVDedit. Choose your VIDEO_TS folder. Select one of the VTS sets and click the IFO button in the lower window. You'll see a button showing the aspect ratio. It should be either 16:9 auto Pan&Scan & Letterbox or 16:9 auto Letterbox. If it isn't, you can change it here (except you first have to change permissions on the VIDEO_TS folder to allow Read & Write). -
In my experience all DVD players, when given a 16:9 to play on a 4:3 TV, do the letterboxing automatically. you do not need to do anything at all.
Alph
VOB conversion help
By MarkL1986 in forum Video ConversionReplies: 4Last Post: 14th Feb 2011, 10:10 -
VOB to DV conversion
By candy56 in forum ffmpegX general discussionReplies: 12Last Post: 29th Dec 2009, 00:53 -
.vob Editing/Conversion
By matedog in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 12:27 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Converting .VOB or MPEG2 from 16:9 to 4:3 Letterbox
By g1275 in forum EditingReplies: 6Last Post: 17th Aug 2007, 09:11
