hi, how do you burn an ISO image? I use to use Alcohol 120% but it expire. I need to look for a new software. I have Nero but have no idea how to use it. I try using it but the image is safe to the computer instead of being burn. Really confusing for me. Can someone please help.
It sounds like you have selected the 'Image Recorder' as the recorder to be used...
Open up Nero...I try using it but the image is safe to the computer instead of being burn.
Select "Recorder"
Then Select "Choose Recorder"
Make sure your Burner is selected...If it isn't click on it. Click on OK.
Click on "Recorder"I have Nero but have no idea how to use it.
Click on "Burn Image"
Locate and double click on the image file
Insert a blank (if you haven't done already) and click burn
burnatonce is an option...very very simple to use...I need to look for a new software. -
OMG, I did what you told me too, and it work. I am so happy right now. Thankyou to all your reply. It help me out a lot. Thankyou to compuser, and Sifaga.Originally Posted by compuser
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
to iso or not ?
By dr.bling in forum Authoring (DVD)Replies: 14Last Post: 11th Apr 2010, 08:05 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
ISO
By bogb in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 12:08 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
