Hi,
Whats ur recommended tool to reduce bitrate?
Results 1 to 13 of 13
Hi vocalmind,
You're gonna have to provide a lot more info...
Audio?
Video?
What format?
What tool was used in the first place, if any?
What are you trying to achieve?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Sorry for the confusion. I mean MP3 audio.
Its like i want to reduce my 192kb to 32kb...
Thanks for the reply... -
That's a huge bit rate drop. You should convert to mono so you'll have perceived 64 kbs quality.
Razorlame , a GUI front end for Lame, will do the conversion for you. -
Audio bitrate takes up almost no space.
You won't save anything.
Leave audio at least 192k minimum on AC3 or MP2
maybe 128k minimum on MP3Want my help? Ask here! (not via PM!)
If you really need to go that low-consider conversion to wma audio or real audio-at least the vocals will remain reasonably clear.
...or .ogg at really low bitrates. Only got a 16 MB memstick in my phone, and listening to MP3 below 96k is unbearable. ogg, @ half that rate is tolerable, actually.
/Mats -
If reducing audio bitrate doesn't save anything, then I'm assuming reducing video bitrate does? If so, how do I do this?
Thanks! -
Originally Posted by faeriedust66"Art is making something out of nothing and selling it." - Frank Zappa
the video files are in avi format.... i have MainConcept Encoder v1.50 .. i don't think this gives me to option to reduce video bitrate? or does it? can you suggest a program that does?
thanks! -
Now fill in the blanks (copy and paste)...
"I have an avi in ____ video format and _____ audio format, it is ____ minutes long and ______ KB in size.
I wish to make it ________ KB in size keeping as much quality as possible. What tools/steps do you recommend?""Art is making something out of nothing and selling it." - Frank Zappa
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 04:17 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 21:25 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 05:59 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 09:32 -
How to reduce video bitrate ?
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 04:47
