I am having trouble burning .bin and .cue files to a dvd. I can easily do it to a cd-r but I can't burn to dvd, any suggestions. Please thank you![]()
Depends on what you are using to burn. In Nero 6, just select 'Burn Image' under 'Recorder'. Then select the 'CUE' file.
i think you need to extract and burn
this link may help
https://www.videohelp.com/forum/viewtopic.php?t=253441&highlight=cue+bin -
Tough to understand what you're attempting to do, first of all.... It sounds like you're attempting to take a CDR image and burn it to a DVD. I don't think you can.
If you're attempting to burn a DVDR image to a DVD-r, then make sure you have the dvd writer selected as the writing device since it can also function as a CD writer as well. -
If in doubt, Google it.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
