  1. im using pinacle studio 8 to capture some tv shows i taped on vhs and while capturing im getting alot of noise (static) from the audio, lines through the picture and when i watch the mpeg back of what i captured its off sync (the video is fine but the audio lags) now does it matter if its like this and will it work fine once i author it and burn it to disc? any suggestions?
    i selected custom settings and mpeg at 720x480
  2. You are dropping video frames while capping. Buy a Time Base Corrector. VHS tapes are always a problem to cap.
    Oct 2003
    Canada
    If it's any help.
    I had audio video sync problems with Pinnacle 8
    I got Pinnacle 9 and now get perfect captures
    Try their Free trial
  4. thank you, i just tried studio 9 and its sooo much better than 8. no more sync problems at all plus the same video comes in so much clearer
