hi all brought this today as i needed a camcorder and is my first one was hoping it would have everything i needed but nope no such luck.
i brought a firewire card as i was told it would increase the speed on transfers so i can burn my home movies to disc.....but the manual says i need motionDV studio yet i cant find a download for it anywhere.
not even sure the software is usable on the gs17eb model as the manual is somewhat hard to understand but i need some sort of software to transfer the video to my pc so any help i would very grateful for
Hi, try this - https://www.videohelp.com/tools?tool=WinDV
As for transfer speed, if your recordings last for an hour then it will take an hour to transfer to your pc.He's a liar and a murderer, and I say that with all due respect. -
OK so you have a PAL MiniDV camcorder and a IEEE-1394 card and cable.
To get to DVD the basic steps are:
1. Transfer DV video from camcorder to a DV-AVI file (PC) or DV-Quicktime file (Mac) on the PC's HDD. WinDV is a good free program to do this on a PC.
2. Edit the video and audio.
various software*
3. Encode to MPeg2 (DVD standard)
https://www.videohelp.com/dvd
various encoders*
4. Author the DVD
various software*
Also see guides
Convert DV to DVD
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=DV+to+DVD&ho...or+List+Guides
* software exists for each step ot the process. Some is free. Some costs.
Typical commercial software suites that cover all steps include
Nero, Roxio and Adaptec class - very basic.
next tier:
Sony Vegas Movie Studio
ULead Video Studio
Adobe Premiere Elements
Pinnacle Studio
etc.
next tier - semi pro to pro:
Sony Vegas+DVD
Adobe Premiere Pro
Apple Final Cut Pro
ULead Media Studio
Pinnacle Liquid
Avid DV express
etc.
and upRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thankyou to both of you i already have some dvd encoding software like nero 6 and tmpgenc virtualdub etc .....but i guess i was duped into buying the firewire and cable as usb would of done it anyway was told would speed the transfer over i will get what i need and let you know how i got on thanks again
The USB port on a miniDV camera usually only transfers stills and a compressed "streamable" video. To get the full quality of DV you have to use the IEEE-1394 port and "transfer" (not capture) software like WinDV or ScenalyzerLive.
You have exactly what you need. IEEE-1394 is the only way to get a quality transfer from the camcorder to to your HDD and back. DV camera transfer is always 1x.Originally Posted by hades8840Recommends: Kiva.org - Loans that change lives.
Panasonic PV-GS250, software for capturing
By rhuala2 in forum Newbie / General discussionsReplies: 15Last Post: 27th Aug 2017, 16:02 -
AVCHD from panasonic lumix, which software is compatible?
By rocketman778 in forum EditingReplies: 0Last Post: 25th Nov 2011, 16:53 -
Which video editor software for the Panasonic HDC-TM90?
By hmbleservant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2011, 10:19 -
Which editing software for the Panasonic HDC-TM90?
By hmbleservant in forum EditingReplies: 1Last Post: 6th Aug 2011, 23:20 -
AGW brought to it's knees by hacker?
By thecoalman in forum Off topicReplies: 4Last Post: 26th Nov 2009, 05:01
