I'm encoding alot in CVD resolution at 2520 CBR.
Should I use MPEG1 or MPEG2 ?
Which one produces better quality at that fixed bitrate ?
Mpeg2 will work better. If you used mpeg1 it wouldn't be standard for anything. It would be a xvcd and might not be burnable without reencoding.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I doubt if you'd notice a difference, but why don't you do both and see which one you think is best ?Originally Posted by ShinKyo
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
MPEG2 VBR to CBR
By dl_sledding in forum Video ConversionReplies: 0Last Post: 26th May 2010, 12:27 -
MPEG2 CBR with Mencoder?
By RogerTango in forum Video ConversionReplies: 1Last Post: 27th Mar 2010, 23:07 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
