I have an AVI file (Xvid/AC3), and when I demux the video and audio streams I get a problem.
The first few seconds of the AVI is an "encoded by...blah, blah" message that appears before the movie, and when the movie starts after the message, the audio starts as well - so far, so good - audio and video in sync.
But when I use VirtualDubMod to demux the AC3 audio file and use BeSweet to convert it to an mp2 for use in DVDLab Pro, there is no silence at the start of the audio as there is in the original AVI - so after I demux the video stream in VirtualDubMod and convert to an mv2 file in TMPGenc, I've got two ES files that will be out of sync when used in DVDLab Pro.
Also - loading the demuxed AC3 directly into DVDLab Pro gives an error.
In a nutshell - after demuxing, the video stream still has the "encoded by" bit before the movie, but the audio stream doesn't.
Of course I can use "source range" in TMPGenc to cut the "encoded by" section from the beginning of the video file, but it's a hit and miss affair - I don't want to go through all of the converting to end up with a movie that's only slightly out of sync instead of a lot.
Does anyone have any ideas on a better way to get the streams in sync with great precision? Remember that my end product needs to be mv2 and mp2 ES files.
VIDEO_TS to AVI xVid with AC3 5.1 passthrough - problems
By couldtryharder in forum ffmpegX general discussionReplies: 11Last Post: 29th Nov 2011, 09:08 -
after vob Demux the m2v and ac3 have duration difference
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2010, 01:45 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 20:03
