Does anyone have experience with this model of TBC, or could someone point me in the direction of a site that sells an operator's manual?
I recently picked up a FA-120 and do not understand what some of the settings mean and how they function.
For example, the unit contains a proc amp, and one of the settings is video. This video setting displays a number range that can be toggled through. 00-255. I have no clue as far as what this should be set at.
Here's a link to a data sheet on the FA-120 which includes a block diagram at the bottom:
http://www.for-a.com/pdf/fa120.pdf
Any insight regarding this model would be much appreciated. Thank you for your time.
Results 1 to 1 of 1
Digital Frame Synchronizer v TBC
By david151 in forum Capturing and VCRReplies: 9Last Post: 27th Apr 2012, 20:42 -
DPS 290 TBC/ Synchronizer
By braxus in forum RestorationReplies: 0Last Post: 7th Nov 2011, 01:51 -
For.a FA-125 Frame Synchronizer & TBC
By Cingular in forum Capturing and VCRReplies: 17Last Post: 31st May 2011, 17:28 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40
