This is a TBC Glossary, for the purpose of:
* Researching / Shopping for a board
* Looking for a specific feature for various projects
* Aiding other more knowledgeable members for possible causes
.. or fixes in one's project (regarding TBC as topic, and maybe
.. leading to a more advanced TBC version)
* ect.
If this could serve as a general audiance Glossary, I and/or
one of the Mode members could: revise; clean; update; reword; ect.
as the need requires.
Also, maybe we could refine the specs to just the few more important
facts to know, and possibly reduce to a three-line glossary of each
TBC device, and just make a pointer/url reference to the complete
specs of a given device, such as an html link or pdf file.
- Comments and Suggestions are welcomed.
Spec Sheet:
--> TBC-100 -- (in pdf format)
Inputs:
** Y/C Video (S-video) 4-pin 75 ohm DIN connector
** Composite video 75 ohm RCA connector,
** level: 1.0 VP-P
Outputs:
** level: 1.0 VP-P/Unity
General:
** Frequency response S-video 4.5 MHz +/- 3 dB
** DG, DP +/- 2%, 1
** S/N Ratio >50dB
** Component Y.U.V. 4:2:2 8-bit, Y: 13.5MHz
** Single channel full frame Time Base corrector
** Auto Detects NTSC and PAL signals
** Power requirement DC +5V/700mA or +12V/150mA
** Ambient Temperature range 32’-131’F (0’-55’C)
** Ambient Humidity <90
-vhelp 3508
Results 1 to 1 of 1
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
