hi
is there a software that can help me to put audio video in synch.
sincerely sid.
https://www.videohelp.com/forum/search.php
Been covered countless times.Want my help? Ask here! (not via PM!)
i searched and could not find a specific soft that can help to delay the audio in order to synch with the video.
any better ideas?
thanks too much.
Basically, you have to take A + V apart, adjust the audio (add some silence or cut some off at the start) then put it back together again. What tools to use depends on what kind of video we're talking about. There's no General Purpose Audio Sync Fix app.
/Mats -
If this is an AVI you have, you can do it without demuxing. Open the video in Nandub (or any of the other Dubs). If using Nandub, Set Video for Direct Stream Copy, then go Audio->Interleaving->Audio Skew Correction->Delay Audio Track By xxx ms, and then File->Save As AVI, give it a new name and wait a minute or 2. If the audio is MP3, leave the Preload and Interleaving at default values. If the audio is AC3, then maybe set both for 96 ms.
this video is mpeg2 captured from old vhs tape(pinnacle capture card). considering your tips, i think i have to separate audio and video in order to fix it. right?
thanks too much. -
With video redo you don't have to demux.If you only have 1 mpeg to do,get the trial version if there is one.
bmiller,ont.canada
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 21:45 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 21:59 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Dec 2009, 23:39 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 12:19 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
