Okay I changed my script a bit. But I still need advice to see if it is correct. I am converting VHS -> DV -> DVD. Do I have the DeSpot line correct? I assume I don't need "interlaced=true" for the DeSpot plugin? What about ConvertToYUY2()? Is it best to do this, before Weave()?
Code:AviSource("f:\video.avi", fourCC="cdvc") LoadPlugin("d:\program files\video\avisynth\plugins\despot.dll") LoadPlugin("d:\program files\video\avisynth\plugins\depan.dll") LoadPlugin("d:\Program Files\video\AviSynth\plugins\reinterpolate411.dll") # # Fix DV to DVD color (Use before any ConvertTo... function.) reinterpolate411() # # Assume Bottom Field First AssumeBFF() # # Separate Fields from Frame SeparateFields() # ConvertToYV12 v=ConvertToYV12() # # Makes 3 copies of each frame for motion compensation d = DePanEstimate(v,range=1, trust=3, log="depan.log") DePanInterleave(v,data=d, prev=1, next=1, matchfields=true) # # Despot - remove noise DeSpot(p1=24, p2=12, pwidth=20, pheight=4, mthres=20, motpn=true, dilate=1, seg=2) # # Recover original frame SelectEvery(3, 1) # # convert back to YUY2 for Cinemacraft Encoder ConvertToYUY2() # # Combine both fields back into a frame Weave()
Results 1 to 1 of 1
Despot plugin does not work at all
By Umen Pich in forum EditingReplies: 47Last Post: 21st Jul 2012, 02:35 -
How to get DePan for AviSynth to fix Screen Shake?
By VideoFanatic in forum RestorationReplies: 45Last Post: 30th Nov 2011, 07:49 -
Any good tv script sites online?
By yoda313 in forum Off topicReplies: 4Last Post: 24th Jan 2010, 09:29 -
What's a good script to work with my video?
By rocky12 in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2009, 20:23 -
DeSpot Filter Question
By mcpogue in forum RestorationReplies: 1Last Post: 27th Feb 2008, 15:14
